Hi Folks, Just purchased a new Raptor SD 36 for my yard work. Upgraded from a Cub Cadet LTX1046KW. Impressions so far; 1. A bit disappointed that Kawasaki engine no longer available. However Kohler 7000 series seems ok. 2. Unit does a great job cutting grass. A bit of a learning curve in ZTR driving , but am getting better. 3. Changed the oil/filter at about 4 hours with dino 10w-30. 4. Need to purchase a blanking plate to eliminate side discharge chute for mulching clippings. (did same on Cub Cadet) Any sources/suggestions ? 5. Anybody else have the 36" cut ? I got it due to trees and gates in my yard.![]()
update:
Now have 2 seasons experience. Have added an exhaust baffle ( was burning lawn if left stationary for awhile ),engine guard and a mulching kit. Replaced blades after one season withOregon G3 mulching blades.They are way heavier and seem to cut well
Hi Lafitte,
Are you using the Oregon G3 mulching blades with your mulching kit? I was thinking to use either the G3 or G5 blades, but everyone on these forums don't recommend Gator blades with factory mulch kit, they were designed for side discharge.
Can you please enlighten me with your current set up and how's it's working out for you?
Andy
In a nutshell. Some yards are more obstacle than yard.Probably because the 60" deck will only be able to mow 1/2 the yard because all the trees are too close to the fence or the shed or the car port or the garage or all 3 and the swimming pool is the minimum 48" from the fence so 60 won't go there either or around the flower beds, the BBQ pagola and the hot tub.
Could not count the number of customer who upgraded from the std 32" to 48 deck for a big 60" only to find it takes twice as long to mow and the deck scalps everywhere.
He has a 3/4 acre block so unless he is living in a motor home there would not be any more than 1/2 acre to mow max.
If it was 4 acres and he had a football field lawn things would be different.
Question, file it under serious please.
Why would you purchase a 36" ride on mower for a 3/4 acre yard rather than just make a larger gate for a few dollars and then purchase a 60" mower and be done in half a hour with your entire yard front and back?
Ok, thanks.
Max
No Sir, I don't have to feel good about myself because I may or may not have a larger deck cut. If you're happy with the 36 why would you give a shyte what anybody else thinks?
My time is valuable thus, I'll get the lawn mowed and get on to other things. The cost per square foot mowed is less with a larger cut and my unit doesn't scalp. Sorry to disappoint.
Sorry you may have felt slighted because you have a tiny deck.
