- Sep 24, 2017
- Threads
- 283
- 6,839
I've only used a raisman part once, starter recoil for a briggs 190cc flathead.. got it from Jacks small engines.
Wow.Never heard of them prior to this thread, & I'll stick to my NGK plugs..
About Raisman:
RAISMAN is a global supplier in the outdoor power equipment parts industry. Our Product Line covers most of the well-known OEM’s in the market, presenting top quality aftermarket replacements at factory-direct prices.
Headquartered in Miami, Florida and with facilities in China, Argentina and Brazil, we cover all continents, maintaining active business with more than 250 customers worldwide.
Raisman started back in 1983 in Brazil where we established a carburetor factory with the sole purpose of making Ethanol resistant parts for small engines (the first in South America).
From our manufacturing facility in Brazil we continue to supply 2 and 4 stroke kits and carburetors to all large National Distributors in the US and Europe.
In 35 years, the company evolved to being a reliable source in the market, offering more than 3,000 parts to lawn & garden, forestry, marine, light construction and GOLF/ATV equipment.
At our Distribution Center in Florida we keep inventory of all products and process customized orders according to customer’s packaging requirements, all at a world-class customer service level.
Often the rc12yc where recommended is a bit cold and in fact B&S has said if the plug is blackened to move to rc14YC which we find more often than not is the plug to use.RC12YC have always been 5/8 (16mm) hex. But not NGK make the same plug with 13/16 or 5/8 hex depending on the part number. Some equipment is too tight fro the 13/16 hex so I install the 5/8 hex version without ill effects.
Kawasaki Mules model 600 and 610 had trouble fouling spark plugs, many machines affected. Had a few people go to the dealer, they'd put new a carb on or clean the old one, etc, still after a few hours, plug would foul.That engine takes a BPR4ES plug. NGK plugs are like this the lower the # the hotter the plug. Where as the champion runs just different the higher the # the hotter the plug. We are having a lot of trouble getting the NGKs so are using the Champion RN12YC instead. Looks like the only difference in the RC12YC and the RN12YC us the size socket it takes to take it out since the heat range is the same.
