KM Richards
Recently got a new Toro TimeCutter MX 5475 which seems to be working great after having used it just 3 times to mow my large yard
Instructions say to change the oil after first 5 hours of use so just curious is any body know the Wix oil filer part number for Toro 136-7848
Also, does anybody happen to know if Toro offers an oil drain hose to screw in to the block? There appears to be a port so I'd like the convenience of having a hose screwed in there so I can take the plug off the end of the hose when draining the oil.
I found a Oil Drain Hose Asm - Toro Part Number: 117-1261 at
www.ereplacementparts.com
Think this would work for my application?
I suppose I could make it work by using adpaters, but I don't know the thread size in the block yet...
Hose-drain, Oil 117-1261 - OEM Toro - eReplacementParts.com
Buy the official Toro Hose-drain, Oil 117-1261 replacement - Use our model diagrams, repair help, and video tutorials to help get the job done.
