Redmichael Forum Newbie Jul 22, 2020 #1 I have a hustler fastrack super duty. Anyone have a problem with driver pulley? I have had to replace the driver pulley 4 times in 8 years. Just curious.
Redmichael Forum Newbie Jul 23, 2020 #5 The pulley underneath the hydraulic fan. The pulley connects to fan. Usually when it stripps out the fan spins off
StarTech Lawn Royalty Jul 23, 2020 #6 Are you torquing it to specs. If so you might need use some blue Loctite as it sounds like the nut is loosening over time.
