Question: Huster Fastrack Super Duty pulley
Redmichael
I have a hustler fastrack super duty. Anyone have a problem with driver pulley? I have had to replace the driver pulley 4 times in 8 years. Just curious.
driver pulley ?
please explain which pulley
Redmichael
Sorry. Yes driver pulley.
Redmichael
The pulley underneath the hydraulic fan. The pulley connects to fan. Usually when it stripps out the fan spins off
Are you torquing it to specs. If so you might need use some blue Loctite as it sounds like the nut is loosening over time.
