K KennyV Lawn Pro Nov 7, 2011 #11 Duramax said: i ... what is the best way to attach a pulley to the crank shaft? Click to expand... Was it not originally just a key with a bolt holding it on?
Duramax Forum Newbie Nov 7, 2011 #12 KennyV said: Was it not originally just a key with a bolt holding it on? Click to expand... correct but i flipped it upside down to use the deck/blade pulley because it is larger. the keys where on the top side not the bottom and the bolt will not mount or thread the same way. i will try to get photos later
