pulley removal
Duramax
i have a murray hydro auto wide body 17 hp that i took off the deck and blades and i cannot remove the transaxle pulley. took the nut,washer off beat it with a hammer , put a torch to it, and drove it with the nut removed to try to get the pully off and no luck. anyone know how to remove this thing?
this is what the transaxle looks like with the pulley. obviously its all still together in the frame
i dont have the correct size puller...but one of my buddies has one that i can use next time i see him.
it just seems like there is something else holding this thing in. there isnt really too much rust and i sprayed an #ss load of PB blaster and wire brushed whatever was on the shaft.
i guess its just froze on? or does anyone know if im missing something?
Sometimes things just get tight...
There isn't an allen screw in the hub, over the key is there... :smile:KennyV
I've had some pulleys with multiple set screws around the hub... removing only one would never allow it to be free of the shaft... :smile:KennyV
sorry for stupid questions but where would these set screws be? ive looked all over this thing and cannot find any evidence of anyhting else holding it on
i decided to leave the rear pulley on because i couldnt get it off w.out ruining it. so now i have the front pulley off that was attached to the engine. i want to put a bigger one on there, what is the best way to attach a pulley to the crank shaft?
