PTO/Clutch Issue
bamadirtrider
Once you get down to under 1 ohm its takes a milliohms meter to measure that and most el cheapo meters simply can't read accurately this low.
But yes a clutch that is partially shorted can still operate but will over the charging system and a lot of the time start melting connector and burn off wire insulation. That PTO clutch should not be pulling more 7 amps at the most so install a 7.5 amp inline with the clutch and if blows replace the clutch.
He put an inline fuse of 7.5A in circuit and blew it immediately: the blades didn't even try to turn. So He'll be ordering a clutch.
Thanks for the info. Now to find the best deal on a clutch. Any suggestions/recommendations appreciated!
about a 2019 model.
Scag PN 462339 around $400
Xtreme X0651 (order thru Stens or Xtreme, One year warranty). About $260, Better clutch and less than the price of the Scag if you buy direct and install it yourself but please the install instructions.
bamadirtrider
about a 2019 model.
Thanks for the help. Will do.
I will double up on what Star said
I managed to totally stuff an Extreme clutch by using my rattle gun
Expensive lesson learned
Had to make an offset open ender from some scrap 3/16" steel plate to hold the crankshaft from turning while tensioning the clutch.
And I know it will sound silly, but the dome washer ( where fitted ) is a lock washer and yo goes on so the bolt head compresses the dome
bamadirtrider
Appreciate that info. Will tell my neighbor to read up some before attempting replacement!
Copy of instructions and warning label just in case you don' t get them. Also make sure you
use anti seize compound when installing on the crankshaft. The next tech will thank you.
Image of the warning label, ignore the tools as those are installing a different style of
clutch but the warning is the same. Proprietary custom tool masked out. Not used on
Scag setup.
bamadirtrider
Scag setup.
Awesome info. Might have just saved him some extra dough! Appreciate it.
Over the years I have gotten smarter or perhaps lazier not sure
Now when I fit a clutch I run a stud up the crankshaft , slide the clutch up till it just touched the end of the crankshaft then tighten a wing nut to draw the clutch up
So much easier than trying to hold it up laying on your back with the pulley in front of your nose .
The when you get to slot for the key it is just a case of a bit of a jiggle to make sure it is lined up.
Extreme put a square punch mark in the clutch to show you where the key is which is very civilised of them and was not in my instructions .
Still takes me 1/2 hour then again I could never get an LP record on the turntable is one shot either .
