Wow!! Now you have me a little confused. Throttle is working in reverse ? Humm.....The only way I know that the throttle will work in the reverse position is if the throttle lever has jumped the throttle stop on the carb. See the attached photo. As for it not wanting to run with the air cleaner off puzzles me mine runs perfect with or without it. Check make sure the throttle hasn't jumped the stop on the carb, and let me know. Take another pic on the carb I would like to see it. Don't get frustrated that's when we start to make mistakes :thumbsup:
Thanks for getting back so quickly! The throttle lever has definitely not jumped the stop... I will get a pic asap, but if you look at the lever where the governor spring is attached, try to visualize it being bent so far to the left that it goes around the other way, so far that it reverses the angle of the governor control lever so that fast means slow and vice-versa... But it took bending it that far to take enough tension off the spring and get the idle down! That's why I asked whether you think the governor is still not adjusted properly, or if there culd be something wrong with it... Or if I could adjust it a little ways away from the static position.... There's definitely no binding of the governer lever now....
