Hey all - I have a really new Poulan Pro PR2322 gas hedge trimmer, maybe 10 hours on it, that just won't start and run anymore. Granted that there's basically nothing to those carbs...only takes a couple minutes to take it apart, clean it, and put it back together... And I made sure the supply line from the tank was free and moved gas. But it clearly just doesn't get fuel through.
It looks like such problems are common, not with just this model but cheap small chainsaws, trimmers, etc. across the board - and there are TONS of aftermarket carbs for these types of things for anywhere from $10 to $30, so I'm thinking that the stock carb must just have such a poor design and/or made out of such cheap materials that it just doesn't work for more than a few hours.
The problem is that, although the carb for this unit is pretty much the same thing as for a small chainsaw, trimmer, whatever, I can't find an aftermarket carb that is listed as explicitly fitting this unit. I'm sure it's identical to a carb for some other device - I'm just not sure which one. Does anyone happen to have any idea what aftermarket carb would fit this Poulan Pro PR2322?
![IMG_20200618_1832051[2].jpg IMG_20200618_1832051[2].jpg](https://www.lawnmowerforum.com/data/attachments/41/41761-87321cc4e681e633de99b0f059d6586d.jpg?hash=hzIcxOaB5j)
