OK. I took this thing apart and replaced the cylinder, piston & ring. I followed a VERY good tutorial on the subject here:
tutorial video <<
So now I have replaced every fuel component but the tank, the plug, ignition coil, air filter, carb, cylinder, rings, piston.
It still will not fire once.
I looked at the plug when jumpered to the cylinder head and it has spark. It appears to be getting fuel.
So here's the only thing I can think of. In that video he runs a bead of gasket maker on the crank case where the shaft bearings seat (at 20:20 in the video). I failed to do that but I also noticed that there was none there when I took it apart. Is that a normal thing to do and could it be causing enough of an issue that it wouldn't hit at all?
Otherwise I'm at a loss.
