please read and reply, i need advice on how to modify my mower
logert gogert
  • / please read and reply, i need advice on how to modify my mower
yes sir, thank you you for evrybodys time, with helping me and replying, im surprised you guys even replied, and thx again for not losing yalls mind, hope fully when i get another mower, yall can help me then. now..................i will go cry myself to sleep after buying this mower with hopes that i can make it work then it doesnt. just kidding, but seriously thank you guys :)
look up mower racing.
There will be a groups of "weirdos" somewhere near you.
Get some one to take you to the meeting and take photos.
Note which makes & models they are using, cause that is what you are looking for.
Provided that the mower has not blown up bewen heats most will happily point you towards all sorts of things that you can do to get a bit more out of any mower.
Just remember they are very basic engines so flywheels, crankshafts pistons & con rods have an aversion to doing much over 5000 rpm.
It is very expensive to get them spinning much faster
Look for a mower with a horizontal shaft engine that you could replace with a small motorcycle engine.
For your purpose that will work well.
Or go down the cart route and get a chain drive mower and couple it directly to the motorcycle gearbox sprocket.
logert gogert
thanks, but i was always thinking of keeping the original motor and just modifing that
logert gogert
damn
wheres the ice cream cause ima shove me face wit it and cry my self to sleep
wHy YOu GoTTa ReALitY ChEcK mE LikE ThAt
logert gogert
hey, its me.......again (*sigh*).
since i cant sell that hydro mower, i was just going to keep it and use it to haul stuff around, pull my mowing equipment ect.
but its whining alot, and i decided to come here and ask yall if i should replace the fluid in the transaxle.
thank for any help.
Scrubcadet10
Moderator
Staff member
Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed.
above is quoted in the service manual
logert gogert
im not doughting your knowelege in any way, but i was reading that there is a fill nozzle that you can unscrew and fill up, and people have had whining hysro transmissions and they change it, and it completely stops the whining
