- Feb 19, 2020
- 121
- 12,883
The comment was not direct at you but at another poster that assume I didn't do my research for the correct part number. Of course I didn't give the OD as I assume it would be the standard OD but that not as important as the ID and length. The only time OD become overly important on hoses is when you having to feed them thru the engine such as between flywheels and crankcases. Tecumseh engines are one these engines that a standard 1/4 id fuel just won't fed thru. That because a standard 1/4" has an OD of 1/2". In these cases I need the 1/4" ID and 7/16"OD line.What the hell, dude? I was very much helped, and given the specific part for my model number. No need for such aggression, sheesh
