Parking Brake Question MTD J136
paulbaker1954
When I get off the seat with the park brake engaged and the deck up the engine still stops.
If I push on the brake a bit harder then engine does not stop if i lift off the seat.
It would seem that the brake pedal needs to be held further down when the lever is moved to park
My problem is I cant figure out how to adjust to fix
Can anyone help please
The switch is probably just worn out and needs replacing or there is wear on the mechanical points.
I usually extend the plunger by putting a self tapper in the end of it .
