I see many designs and models of lawn mowers. They all look the same :smile: I wonder which brands have quieter engines. I also wonder which brands consume less fuel. Any idea? Thank you.
Personally I don't believe you'll find any lawnmowers that are quiet, :smile: at least gas operated mowers. The smaller push mowers (5hp and less ) maybe a little more tolerable because of the smaller engines and IMO the Honda engines on smaller mowers give you the best fuel consumption.
The larger walk behinds IMO would be next inline with the 15hp and less. If you're looking at riders I would have to say the Tractor type would be the noisiest of the riders because of the front engine placement.
The ZTR (zero turn ) mowers are less noisy to the operator again because of the engine placement. As to which brands consume less fuel, that's hard to say because they're to many variables involved in the running of riding mowers.
Some people will say that the tractor type mower will be the cheapest to run.... but in reality it may not be. If you use the typical home owner on his 20hp tractor and say it takes him 30 minutes to mow his lawn, then let a lawn care person with a 20hp Ztr do the same lawn and it only takes him 15 minutes to do the same lawn, who's using more gas?
Engine displacement, Maintenance, Mower type, Operator, all these things and more play a part in fuel consumption they're just to many variables to tell what gets the best fuel consumption.
