- Nov 29, 2014
- 24,995
Get another head gasket and pull the head.
Look for damage to the top of the piston from it hitting the valves.
lap the head and the block flat, they tend to go hollow on the thin wall between the cylinder & the pushrod tube,
Rotate the engine and check the valve timing.
Those engines will run 1 tooth out either way, for a while.
Pushrods do not bend for no reason.
They bend because the valve does not move.
If it was sitting on the edge of the valve follower ( we have all done it ) then the valve spring will coil bind and that will bend the pushrod.
