OK, so neither the silver series or the part's mower's deck plates work on this deck, they both overhang the front of the deck by 1/2 to 1 CM. I'll try to restore the original but I'm afraid that it may simply be too far gone and needs to be replaced with a better one. What I may do is install one of the spares until another like it pops up, or maybe even try to trim the black silver series plate and paint it. Other than the overhand it fits and does the job. The spares I have are dished where the original is not, and feels like a solid brick of plastic.
The tires and wheels are also pooched, I have the right size of ball bearing wheel for the rear that I picked up for my '67 Gilson snowblower, luckily I haven't welded the stub axles to them yet, so I just need to go pick up some wheels for the front.
Here it is, the deck is down to nothing but the deck, and the engine is removed. I think all I'll do to the engine for now is clean it up and paint the muffler, there is definitely no lack of compression and from a quick look the seals don't seem to be blowing by or leaking.
The plastic parts have almost all been washed in mild detergent, here is what I got done tonight.
The bolts for the handle brackets, engine mounts and wheel adjusters will be replaced with stainless steel to have a bit more resistance to galvanic corrosion, maybe I'll even put thin plastic washers between the bolt head/nuts and the deck to further increase resistance. I hate rust.
Well, that's all I have for tonight. Maybe this weekend I'll hit up a coin op car wash to pressure wash the engine and deck to get all the crud off. It's below freezing now so I can't use my own, it's hibernating in the basement next to the Lawn-Boy. If I'm done with the mower quickly enough, it's frame will be next for paint, and if I'm REALLY done fast, maybe the Toro will get the star treatment as well. Man I wish my garage was built already, I have such a small corner of the utility room to work in!
