dewguy1999
- Aug 14, 2014
- 145
You can stabilize these cracks by drilling a small hole at each end of each crack (this relieves stress and prevents them from spreading), and putting a bolt washers and nut in each hole. Use locktite on bolt threads. Make sure your use short bolts that don't interfere with blade underneath. If you then repaint, it will hardly be noticed. I love the 19" size Lawnboy mowers. I have 3.
Would a pop rivet work instead of bolt and nut?
