I have a 19 h.p twin cylinder model 407777 type 0124-e1 code 00922yg.i bought this from a guy and he took off the air cleaner and sprayed down the carb and started right up and died .he repeated a few times and got it to run but only with the choke pulled out some.i bought it and figured it needed a fuel filter or carb cleaned.put in new filter cleaned the carb and emptied gas.started it same thing but this time it wont run at all.i took the carb off again thinking dirt got sucked in .same.i pulled the hose off the fuel pump and its coming out.it will run fine if you give it continuous spraying of the cleaner.i checked the needle valve.does this sound like the float might be chacked and staying on the bottom.im putting too much money in this I appreciate all the help I can get.
