Ok, I’ll give this one more try, but I’m not to positive you will know what to do.  If you want to question my ability or what I’m doing, you can do so, but realize I’ve worked on small engines for 50+ years and I think I do know a whole lot more about electrical troubleshooting than you do.  The procedure I posted is one that two of us members developed to help DIY guys test electrical starting systems.  It assumes the the individual has an understanding of basic electrical terms and how to use basic testing equipment.  A test light is very, very seldom hooked into a circuit the way you described you did.  If you are using a test light instead of a VOM to do these tests, the clamp should be connected to a good earth ground and the probe is then used to trace voltage.  What you did was jumping the circuit between two points, bypassing the solenoid.  You could do the same with any jump lead.
Now you say my procedure is just a cut and paste plagiarism, so I guess you really don’t know how to follow a systematic procedure.  I guess you were doing something else and didn’t read this part of the procedure.
“Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.”
That being said I wish you good luck in solving this problem without spending too much money on parts you don’t need and burning your bridges with other members of this forum.  I will be following this thread, but I can’t help you because you can’t follow simple directions.  Bye, Bye, Bye.
