I looked at the flywheel cover on my 3.5 B & S engine and cannot find the model #. All I see is the B & S label with 3.5 HP on it. Is there another way to identify this model. This engine came from an old lawnmower, but have been using it on a tiller. Engine ran very well on last use, but was smoking terribly. Engine just about always started on first pull even after long storage, but always had oil in the cylinder and muffler until it burned off. Then it just started smoking all the time. I would like to rebuild this engine.
