Clean the carb & replace the fuel lines outdoor power infoHas a walbro carb...283707-0117-01.
Occasionally gas gets into the oil. Helps if I shut the fuel off after use.
I understand a stuck needle in the bowl can allow gas to get into the
crank case. Is that correct? thx in ad...
Received them both. What's the easiest way to remove and install the seat? tia
