OK... Let's See Your Mower!
MowerMike
Family Photo
From left to right in front view photo:
1) WORX WG782 14" (13" blade) 24 volt lead acid battery powered push mower
2) WORX WG786 15" (14" blade) 24 volt lead acid battery powered push mower
3) Greenworks 25252 16" (15.5" blade) 40 volt Li-Ion battery powered push mower
4) Earthwise 60120 20" 24 volt lead acid battery push mower
5) Husqvarna 7021P 21" Honda GCV160 gas powered push mower
Note the modification to the Husky mulch door with the clip to keep the blasted thing closed and the 1" larger front wheels on the Greenworks to increase the cutting height and level the deck, which was tilted downwards toward the front. Also, if you look real closely at the handlebar on the Husky you will see a loose strap which I slide over the handle to keep the bail bar pulled back, so I can step away from the mower to remove debris from the lawn w/o having to shut the mower down and then restart it. And, no, I don't really need 5 lawn mowers.
Impressive! Nice collection. It is always nice to have a gas mower for thicker grass.:tongue:
dlc49
Have an older Grasshopper 718 and mow about 3 acres @ home and about 2 @ a church nearby. When I had some engine issues last year I picked up an even older 718 for backup, ended up doing some work on that one too.
:welcome: to LMF!
notmenotme
Here is a picture of my 1976 Cub Cadet 1650. It is still very dependable and a great help.
turfsurfbob
Your mower looks great for as old and well used it is. Looks like the older machines were better built .
Well, just joined today and now, I just have to fab up some bracketing to hook up a deck up to this....No Just kidding....I will be posting pics of my past tractors and the one I just bought....2006 legacy xl w/48" deck and picking up a loader for it out of Indiana in a couple of weeks. Owned Simplicitys for the past 26 years and wouldn't change...love the dependability and THE CUT!! Thanks for looking!
OK that's cool!
