Hammermechanicman
- Jan 10, 2020
- 69
- 3,915
The biggest problem with that type of hone is that the face of the stones are flat. When you put them in a round cylinder the sbarp edges of the staoes are what makes contact. No matter what grit you get the stone's sharp edges will gouge the aluminum. 30+ years ago you could get stone's with radiused faces that worked on aluminum. Also if not experienced with the spring hone it is very easy to put vertical grooves in the bore inserting and removing it. Another problem with the spring hone stones is that the material will load up an cause scratches in the finish. Ball hone much user friendly. I put the cylinder in a bucket of kerosene. Remember! You only get one shot at it. If you must use a spring hone get 600 grit stones. The cheap Chinese stones are always more coarse on aluminum than what you think and the one you linked to lists 220 grit stones that will destroy an aluminum cylinder. I ruined my share of 5HP Briggs engines learning these things.![]()
Engine Small Brake Cylinder Hone 32-89mm Bore Honing Tool Flexi Shaft S-2ECH3 on OnBuy
SATRA S-2ECH3 is engine cylinder honing tool with adjustable tension. Perfect for honing and de-glazing car brakes and clutch cylinders. Size...www.onbuy.com
Would this home still be ok as this was the one I had ordered before I saw your message.
