....Any way to check to make sure that is what needs to be replaced? ... Is this doable for an enigine novice?
Ryan
Hello Ryan & WELCOME to LMF...
It most likely is the seal at the crank... BUT it could be a drain plug came out... wont hurt to look...
Clean it up under the deck (Use spray brake cleaner) then dump a pint or so engine oil into the engine and let it set for a bit and look what has oil on it... that will be where the leak is at...
Shaft seal is not hard to replace, getting it out is going to be the biggest challenge.. Pay attention to the direction it comes out, don't put the new one in upside down... Easy to do & if the mower otherwise is working ... it's always better to repair than replace especially when the repair will only cost a couple $... :smile:KennyV
