Start simple, make certain the blades are not engaged or anything else isn't pulling on the engine, check that flywheel key, make sure the valves are adjusted to the proper clearance and make sure whatever wiring you are using to crank it is capable of the amperage load a starter will put on it. I'm assuming nothing is making contact in the engine, such as sparkplugs being too long and contacting the engine or valves being too tight and bottoming out as they open. If the key is good, you have the correct sparkplugs and you're certain the jumper cables are in good condition, then I'm thinking either the valves are still not in spec, the decompression mechanism is not working or you do have a weak starter.
