- Nov 29, 2014
- Threads
- 65
- 24,995
OK, so you have a 4 pole solenoid, two big ones for the starter power and two small ones for the control ( trigger ) .
In that case one of the control wires should go + 12V when the key is in the start position.
The other wire must go to ground when the key is in the start position.
The latter is done via a relay.
The concept of switching grounds on & off confuses a lot of people.
I am sorry, I should have looked up your actual wiring diagram before posting my response.
Usually yellow, white or orange coloured wires are used for the + 12V trigger and brown, green or black for the - trigger.
I can not get a wiring diagram for Hayter on line so it will be difficult to work this through with you without one.
From memory they are the UK brand for Stiga made by Global Garden Products.
There should be a wiring diagram in your owners manual if so could you scan it and then post it to the forum you will get better solutions.
If you have a 4 pole solenoid it should close & crank the engine when one of the trigger wires is +12V and the other is ground.
If you have a 3 pole solenoid it should fire when the trigger wire ( the one near the bottom with it's own spade terminal ) is 12V and the body is ground
So jump the trigger terminals and see what happens.
a photo would help a lot as people get confused with the power take off from the hot terminal on the top of the solenoid.
As for your lights, there are 2 systems used
1) runs them off the battery
2) other runs them off the alternator so they only work when the engine is running.
