I was thinking about that ground thing too. Hard to pull the pull chord, while grounding the coil at the same time. One almost has to have two people. Unless you have one of these.Try that again while touching off on ground with your hand , if it is a good spark it should make your muscles react
The last time I literally stuck a screwdriver into the plug wire and held on to it didn't get the least amount of shock I've never seen a bad flywheel but that's where I'm at it's still magnetic I have no clue why this thing is not getting spark and yes it very well could be cursed
Just for grins, pour a little gas or some carb cleaner into the plug hole or through the carb and give it a pull and see if it tries to start.
