- Nov 29, 2014
- 24,995
Absolute rubbishIf the flywheel key is broken, the flywheel probably won't even turn and the shaft will just spin inside the flywheel. Clean the magnet surface and coil surface and stick a piece of paper between the two, about ..002" gap and usually that works for me. Make sure to blow off any steel wool or dirt. They need cleaned often if left in a cold barn over winter. I always try the easiest fix, which is a new plug.
Magnets do not need to be clean and neither do the laminations on the coil.
I strongly suggest you go back & read your science text books from high school
Next the air gap is 0.010" not 0.002"
On a Hall Effect trigger which is what is inside the coil, the closer the coil is to the magnet the EARLIER the coil will fire
Thus you are advancing the timing by reducing the air gap.
You are also making the spark weaker because the coil fires before it reaches maximum voltage .
Neither the coil nor the magnets need to be clean the only important thing is they do not touch.
Next, the key s a timing key not a power transmission key and the engine will run just fine without one all together
It is just there to keep to fluwheel in alighment with the crankshaft while you are tightening the nut down onto the taper which is what transfers rotation form the starter to the flywheel
