No spark with new coil, plug and disconnected kill wire??
olddog
  • / No spark with new coil, plug and disconnected kill wire??
I'm baffled! Started with the obvious by replacing the plug. Then I replaced the coil certain that it would work. There's nothing left in this circuit. Flywheel looks intact.
Any ideas?
Carscw
I'm baffled! Started with the obvious by replacing the plug. Then I replaced the coil certain that it would work. There's nothing left in this circuit. Flywheel looks intact. Any ideas?
Unhook the kill wire going to the coil and try and start.
Fish
What is it? How are you testing for spark?
Carscw
Did you set the coil air cap to specks?
I use a playing card.
Not trying to suggest that you are clueless but I don't know how much you know or what you have done. So don't feel insulted
olddog
It's a simple Ryobi push mower with Tecumseh motor. There's a kill switch with brake and nothing more that I can tell. Magneto looks like it's ok. There's a light smell of gas on the plug after I pulled it.
I am using the new plug grounded to the cylinder to look for a spark.
The new coil was installed using the business card method.
Since the covers were off, I used a rope wrapped around the metal cup on top of the flywheel that normally engages the pull rope. I could not see or hear a spark.
Is the spark so faint that it can't be seen with a gapped plug?
Fish
It is hard to see in daylight, also, put the starter back on to test, you may not be rotating it fast enough. Take it in the garage and turn out the lights.
olddog
Ok thanks, I'll give it a try.
reynoldston
You have nothing else left to try. Either one of the new parts you have installed are bad or as Fish is saying you aren't turning it over fast enough. Put the engine back together and then see what you get.
Two common mistakes to check. One, is the coil installed correctly? The kill wire terminal must be down, close to the block. Second, with the starter off are you spinning the engine over in the correct direction? Either one will not produce a spark.
