And in post*6 you say "Magneto looks like it's ok." did you replace with a new one..?
EngineMan Lawn Addict Joined Jun 12, 2012 Threads 9 Messages 2,275 Mar 1, 2014 / No spark with new coil, plug and disconnected kill wire?? #11 And in post*6 you say "Magneto looks like it's ok." did you replace with a new one..?
T tybilly Well-Known Member Joined Aug 15, 2012 Threads 34 Messages 337 Mar 1, 2014 / No spark with new coil, plug and disconnected kill wire?? #12 also shine up the 2 mounting post with some sand paper,where the coil mounts to.
O olddog Forum Newbie Joined Mar 1, 2014 Threads 1 Messages 6 Mar 2, 2014 / No spark with new coil, plug and disconnected kill wire?? #13 Thanks for all the helpful tips guys. It appears that I do have a faint spark which can only be seen in a closed garage. I am guessing that that is somewhat normal since my only reference is a spark from a car's plug which uses a much heftier coil. It's possible that I always had a spark but didn't realize how dim it was. I'll try cleaning the posts with sandpaper because the mower still doesn't want to start. I already checked and cleaned the brass jet on the bottom of the bowl. And it seems like I'm getting gas into the cylinder.
briggs Well-Known Member Joined Sep 19, 2010 Threads 17 Messages 720 Mar 2, 2014 / No spark with new coil, plug and disconnected kill wire?? #14 hows the compression is there any
O olddog Forum Newbie Joined Mar 1, 2014 Threads 1 Messages 6 Mar 2, 2014 / No spark with new coil, plug and disconnected kill wire?? #15 briggs said: hows the compression is there any Click to expand... Compression holds steady at 80
jhngardner367 Member Joined Mar 1, 2014 Threads 2 Messages 40 Mar 2, 2014 / No spark with new coil, plug and disconnected kill wire?? #16 Are you sure the engine brake is releasing fully,and the exhaust is clear ? Also,make sure the plug wire cap is connected well,to the wire. A bad crimp,or the wire not making contact to the cap could make a weak spark,as could airgap being wrong.
D dennis morris Member Joined Oct 31, 2013 Threads 0 Messages 15 Mar 2, 2014 / No spark with new coil, plug and disconnected kill wire?? #17 Make sure that U have a good ground with the coil and the engine block
