A andrewslarge Well-Known Member Joined Sep 20, 2016 Messages 179 Today at 6:21 AM #11 Is there any linkage adjustment?
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,515 Location Pluto Today at 6:37 AM #12 Sounds like an inversion problem. May require a control kit as either the plastics are worn/broken or small bearing failure.
B bentrim Well-Known Member Joined Sep 7, 2024 Messages 135 Today at 1:05 PM #13 Here is info on the General Transmission. Check the last PDF. You can also explore the website for more Bulletins - General Transmissions Service & Parts services.generaltransmissions.com https://services.generaltransmissions.com/wp-content/uploads/pdfs/bulletins/RS800%20Hard%20shifting.pdf
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,515 Location Pluto Today at 2:55 PM #14 No mention of needing the following tool to remove the inversion system. And make sure you don't lose the 8 steel balls.
