A andrewslarge Well-Known Member Joined Sep 20, 2016 Messages 211 Nov 7, 2026 #11 Is there any linkage adjustment?
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,586 Location Pluto Nov 7, 2026 #12 Sounds like an inversion problem. May require a control kit as either the plastics are worn/broken or small bearing failure.
B bentrim Well-Known Member Joined Sep 7, 2024 Messages 136 Nov 7, 2026 #13 Here is info on the General Transmission. Check the last PDF. You can also explore the website for more Bulletins - General Transmissions Service & Parts services.generaltransmissions.com https://services.generaltransmissions.com/wp-content/uploads/pdfs/bulletins/RS800%20Hard%20shifting.pdf
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,586 Location Pluto Nov 7, 2026 #14 No mention of needing the following tool to remove the inversion system. And make sure you don't lose the 8 steel balls.
R rhkraft Well-Known Member Joined Jun 28, 2023 Messages 133 Nov 8, 2026 #15 If the reverse is based on a push rod, it may be worn and just need some adjustment to push the clevis farther.
