No power on slopes with my zero turn 54" Husqvarna
Cytubb
  • / No power on slopes with my zero turn 54" Husqvarna
The right hydro gear has no power on slopes. I put a new belt on it . There is no visible filter or way to check the fluid. Any help would be appreciated .
Carscw
When on flat ground both levers forward. Does it go to the right? Or go straight?
Model number of mower and a photo would be good.
Serial number from the engine would be even better.
You know what mower you have .
We don't
So we can not help you
