Nikki carb model 808626, brass or silver float needle question
jgentil
  • / Nikki carb model 808626, brass or silver float needle question
Engine: Briggs Vanguard 23 hp, Model 380447-0042-E1
Nikki Carb Model 808626
Ordered float needle kit 808798, Kit has 2 needles in it. One brass and one silver. Engine has a new briggs vacuum fuel pump installed. Is the brass needle used in this application?
My problem is that the fuel pump is over powering the silver needle and causing a rich condition at full throttle. Thanks for your time and help.
Joe
enigma-2
If the instructions don't describe when one or the other is used, try calling Briggs at (561) 880-4022 and ask them. (8-5 est). If anyone knows, its them.
If one is heavier than the other then use the heavy one first
If the engine faulters after a few minutes at full speed under load then swap them over .
Could have a foul seat too. Not letting the needle seal proper.
