NEWBY NEEDS HELP WITH A TROYBILT RIDING MOWER
If the carb is not the prob. The head gasket is bad and needs replaced b/s singles are bad for this.
How would a bad head gasket have anything to do with gas running into the engine?? Just curious on this one? Just my thought on it would be float or neetle valve but who knows I have been wrong before.
Make sure you drain out that oil before you run it again, I understood you to say you drained it to the correct level, it will keep smoking until you get the gas out of the crankcase and fresh oil.
