Fish
The reason it is now taking 3 seconds to stop is because the kill wire circuit is not working, and what is shutting the engine off is the afterfire solenoid on the bottom of the carb, it takes a second or two to burn off the gas.
Could the circuit be disconnected at a different point, like before it goes in the engine? Also, can you post all of the engine's numbers off of the valve cover?
