Repairs New Drive Belt Will Not Propel Lawn Tractor
BlazNT
Nice to see it working.
Boobala
Glad it seems to be workin... I wish he had purchased an OEM belt right from the beginning, MIGHT have
avoided the issue in the first place .. OHhh welll....
BiC
As a matter of fact I did purchase an OEM belt. But, as you saw, it did not avoid the issue. Here's the belt I ordered, part# 140218, which should have worked, but it was too long:
https://www.amazon.com/gp/product/B004QJ30XU/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
OEM isn't all that it's cracked up to be. That's for sure.
mhavanti
BIC,
Glad you're up and running! Now run it like you stole it and if you break it, fix it.
Max
BiC
BIC,
Max
Haha! Thanks! I just finished mowing for two hours. No issues so far.:thumbsup:
stew57
oem is superior and........if you reach your hand up following the brake lever under the frame to the cross member below the brake rod you may find a tightly packed pile of grass a couple inches thick or possibly a stick that is preventing the full and complete release of the brake and thus the lack of trans belt tension. seen that happen a lot.
