Boobala
- Feb 15, 2015
- 7,000
Is the routing diagram on my tractor (and in my owner's manual) wrong?
I am following the diagram from the front of the tractor (engine pulley) to the rear.
I've been looking at this again ...... it DOES appear ...you have the belt routed as per the diagram ...
what I cant understand is ..... IF that pulley (black one) closest to the transaxle is a flat pulley (where the belt rides) that must be
the problem ... meaning the diagram IS wrong... why not try the belt installed on the other side of that pulley (but only if it is a FLAT pulley !! ... see how it operates WITHOUT running the engine... IF it appears OK then try a quick trial with engine running ... WORST scenario it doesnt work & possibly "eat" the belt ...
