Jack_campbell25
- Apr 7, 2020
- 4
This is what’s happening please help
Mower starts but leaks oil
-Leaking oil from what appears to be the head gasket.
-Replaced head gasket and won’t start
-Sprayed carburetor spray in air filter and it tried to start
-Took gas out and put new gas in and sprayed carburetor spray and it started up and black smoke came out of the exhaust and I turned it off
-tried to start it without the spray and then with the spray and it wouldn’t start
-next day saw oil coming out of the valve cover and it seems to be built up in the piston rod chamber.
-new gas, new head gasket, new valve cover, valve adjustment, oil was light brown.
