tyson62792
- Jan 27, 2015
- 1
- 2
Anyone have a crankshaft for a Kohler 17 HP Spec # 24363 or know where I can buy one
I know Kohler makes .010 undersize rods I have not heard of inserts and am not familiar with them, is ths something Kohler has ? The problem with my crank is wear on the main bearing area. Still looking for a used crank don't want to spend $1000.00 for one, might try spray welding the crank and getting it turned back to spec if that isn't cost prohibitive. Never tried it before but I don't see why it wouldn't work unless someone out there does. Used Crank anyone ????
Get the crank ground down to suit a Corrillo custom con rod.
Corillo will make a rod , if they dont have hen as a std item for the mower racing / go cart crowd.
A custom rod should be around $ 200 -$ 300 mark
Off the shelf will be $ 100 - $ 200 region.
Crank regrind will be about $ 40
