Now it only has high gear even though I change gears the speed stays the same
you have to get the GEAR thing out of your head if you want to get this fixed you have no gears just fixed ratios of pulley circumferences which is why I use the stepped pulley drive on a bench drill to illustrate as most blokes are familiar with them..
From what you have now said it seems like the variable speed pulley is sticking .
Without the actual model & serial numbers off the tag under the seat, we can not be 100% specific and the only parts breakdown I have on this computer is for the larger Horse model but the drive system is the same to the point that most parts interchange.
Your problem will be with the double belt pulley part # 47 .
Because of the way it is used it we call it a shive and in particular a sliding shive .
Because all 3 flanges always spin at the same speed, if you alter the circumference of the two pulleys the belt speed in feet per minute changes which changes the speed that the axle pulley rotates in rpm .
THis is what determines your ground speed .
The tension on the lower belt is controlled by the two pulleys # 35 on the bracket # 36 which rotates counter clockwise to increase the belt tension .
The tighter the lower belt is the faster the mower goes.
Your GEAR lever simply limits how far the bracket # 36 can rotate in the counter clockwise direction.
However if the sliding flange on the double pulley # 47 can not slide freely top to bottom then the effective circumferences of the upper & lower sections can not change so your ground speed can not change .
It is a simple system very robust and works very well requiring very little maintenance other than a shot of spray grease on the moving bits every year or so & belt changes.
