snapsstorer
- Dec 30, 2011
- 186
if your engine is a B+S, the manual i have says to start at 1-1/2 turn on both needle's, at a low idle adjust the idle(the one on the bowl) by turning it until it runs rich, then backing it down until it starts to stall. then set it halfway in between the 2. then on a high idle, do the same adjustments as mentioned before. unless it is a fixed jet(high idle). will have to find my B+S manual, just hope my friend did not borrow it again. the last time it took me 2 weeks to get it back.:mur:
