Motoman;
I'll offer the following experiment.
I'll take any of my running riding mowers, run them on the same flat oval (without mower blade engaged) for twenty minutes with conventional 30 wt. oil (Chevron 30 wt.), and then change out the conventional oil and install some Amsoil ASE synthetic. Temperatures will be recorded with an infrared thermometer at the same location on the engine, at the same distance away for the measuring device.:smile: I can't afford an ASTME spec test, but I'll do my best to take repeatable measurements.
