- Nov 29, 2014
- 64
- 24,702
IT is so much easier when people post proper details of their mowers from the first post.
The magneto kill wires are the yellow ones.
To kill the magneto the yellow wire goest to ground
This can happen either by the key switch connecting the yellow to ground
or
ground going through the seat switch then through the PTO switch then to the coil .
So you have either a short in the yellow wire between the seat switch plug & PTO plug
Or the PTO switch itself is grounding the yellow wire via an internal short .
or
