Carb needle sticking open.I sure smell fuel when I attempt to start it
Maybe hydrolocking the cylinder.So I should mention it is hard to pull the rope/turn the engine over.
Pull the oil dipstick and smell for fuel. If it smell like gas, clean or replace the needle/seat in the carb. This was mentioned previously with no action on your part.
Sescond try, where did you get this "new" carb" from?
