navydad2022
I have a question for your expert advice,my mower after turning it off after awhile doesn't want to start but crank,.after leaving it alone it will start.is it carb or coil going bad
It's my snapper rear engine mower 12 hp 281223BVEPush mower ?
Ride no ?
Reel Mower?
Made in Russia , China , Brazil ?
Pull start ?
starter motor ?
21A907-0124-E1 ,12hp electric startupWe need the model numbers off of the engine to be of more help. I would guess the valves are too tight myself.
Both,pull start and electric startupIs it a E mower? (electric only)
Slomo, I'll check it out and do that.Thank you. Is the fuel filter be before or after shut off valve.Vent open on the fuel cap?
After fire solenoid sticking?
Good fuel flow AT the carb?
Can you fill the fuel tank and see a solid flow while emptying the tank out 100%? This should negate bugs and junk in the fuel tank.
