Mower starts good at startup
navydad2022
I have a question for your expert advice,my mower after turning it off after awhile doesn't want to start but crank,.after leaving it alone it will start.is it carb or coil going bad
Push mower ?
Ride no ?
Reel Mower?
Made in Russia , China , Brazil ?
Pull start ?
starter motor ?
navydad2022
Use my snapper yesterday morning and turn on as usual but after shutting it off and coming back to it no starting up .But l left it alone for about 30-45 minutes it starts as normal.any suggestions
Fish
We need the model numbers off of the engine to be of more help. I would guess the valves are too tight myself.
navydad2022
21A907-0124-E1 ,12hp electric startup
Forest#2
Is it a E mower? (electric only)
Vent open on the fuel cap?
After fire solenoid sticking?
Good fuel flow AT the carb?
Can you fill the fuel tank and see a solid flow while emptying the tank out 100%? This should negate bugs and junk in the fuel tank.
navydad2022
Slomo, I'll check it out and do that.Thank you. Is the fuel filter be before or after shut off valve.
