Hey folks. 2006 bad boy ZT with 26 hp b/s engine. Was running the mower for the first time this year and I switched the key off. The engine died as it should but a loud buzzing continued. It sounded and felt like it was completely ng from the starter motor. I eventually was able to loosen the negative cable on the battery and it stopped. But when I tried to continue to loosen the cable it reconnected a bit and the motor then tried and tried to turn over and start ( I think the only reason it didn’t start was because the choke was pushed in and I had only run it enough to move it out of the garage when I first turned it off). While it was still trying to start I lifted the seat and even engaged the blade, thinking those would surely stop it but it kept trying to start. Finally got the negative cable off and it dutifully died. Does this sound like a relay or wiring or solenoid issue? Any suggestions how to narrow my search will be greatly appreciated! Thanks,
Grant
Grant
