reynoldston
- May 23, 2011
- 92
- 5,705
Tapping to the next size does remove material, but that's why you use a bigger bolt. How does that make it weaker?
We aren't getting to the point where the wall behind the threads is getting too thin. I don't think there is any concern about removing material. And tapping to the next size or two is barely any difference at all...
Thread #6 the OP said he used a 3/8 -24 tap and die. You will find that is the original size not oversize. If the threads were bad then he would be removing metal. Not that it matters to me, I wouldn't feel a thing if the blade comes off and hits someone. I suggested he makes sure he tightens the bolt to specs.
